ok im trying to set my valves on motor on the stand and when i do the 1st half i try to rotate the motor to do the 2nd half and it wont let me get the cam at 6 clock and crank at 12
Heres your problem, So do what automotive said and back them all off and start over do one at a time i have seen people do this and the piston hit the valve and break the valve stem off, So pay very close attention to what you have going on remember one at a time JMO. What heads are you running ont it?automotive breath said:It sounds like a piston is hitting a valve. Back all of the valve adjustments
off and set one valve at a time. After setting one rotate the engine over before
setting the next valve.
