53fordguy said:
I have A Few Options With my Build... With The Flatty It Could Really Be A Cool Rod BUt I Also Have Some Newer Engines In Mind (460/429/351) Any Suggestions would be nice...Im going with a flat black and red/chrome wheels(bfg 295/60/15 rear and 255/60/25 on the front) i know the flatty is a cool engine but can i still smoke the tires or should i just build a mini rod and put it in there?
Let me say first that I dearly love Ford/Mercury flatheads. I have had Hot Rods years back with them in it.
Now to your questions.
Yes, you can still "smoke the tires" even with a stock flathead and stock three speed trans. Speedshifting into second will squeal the tires as well. If you have an overdrive trans, you can get 60 MPH in first gear and 90 MPH in second (assuming you have a long straightaway).
Cost is a factor as to your choice. It will cost you about the same to build a "HOT" flathead as any other engine of your choice. In the end you would have a really neat looking flathead that does have a decent amount of HP; but will more than likely run a little hot, have lousy fuel consumption, and will be outrun by many stock late model cars. You would also have to upgrade your trans and rear end if you wanted any kind of longevity (if you "get on it" much). Cruising at todays freeway speeds will be hard on that flathead as well.
If you plan to only drive the car once in a while to rod events, cruise-ins, etc.; then the flathead would be my choice. I would definitely go with finned aluminum heads and multiple carbs. Use a Mercury crank (gives you additional stroke) and a nice 3/4 cam (Isky still makes them), and glasspak mufflers. If you can find them, replace the trans gears with Zephyr gears. You can really wind it up with them. Use 4.11-1 rear gears.
All that being said, the choice is yours. Personally, I'd go with the later engine and upgrade the trans and rearend as well as the front brakes. Dollar for dollar you will be way ahead.
