Doc here,
imp:
If you are getting full voltage during crank to the HEI coil, you should get a strobe on the timing light.
BE sure the light is Power AND Ground at THE BATTERY...not the engine block...your block ground may also be the reason it won't fire and run!
Is the An upgrade to HEI from Points or replacing an engine that had points before? If so, you may have a Resistance wire or resistor on the coil Battery (+) wire feeding the HEI still..you will have to remove this in order for it to run or run correctly. HEI's do not require Ballast resistors.
A Quick test is run a jumper to the battery from the BATT terminal on the HEI cap (coil power) and crank it, If it fires and runs OK, you found the problem.
If not, Pull the Module and take it to the parts store and have it tested (several times to heat it up) and replace if needed..If you get a new module, HAVE it tested also...these have a HIGH fail rate out of the box..like 1 in 3...and when you leave the store, it's your problem. When replacing the module, DON'T forget the heat sink compound or you'll be buying another module within a week..same applies to replacing the used good one.
Test the coil..Measure the primary side of the coil, ( Probes on BATT and TACH) It should read on a DVOM set for R X 1 , less than an ohm...then measure the secondary side of the coil, (Probes on BATT and Carbon rotor pickup under the cap) Set for R X 10k or higher, It should read between 6000 and 30,000 ohms..If these readings are too far off, replace the coil.
If you installed a Fresh SBC...You might require a Secondary ignition wire from the Solenoid,(losing power in crank mode) OR, You may also have Ground issues, Set up ground buss as follows:
Run a properly gauged Ground cable from the battery to any handy bolt at or near the starter, From that same bolt get a Battery cable at the parts store, that has two 3/8 ring terminals on each end and attach it there and to the Frame.
Next get some 10 gauge wire and ring terminals and run that from your bolt on the block to the Firewall, and another to the Alternator bracket or mount bolt.
If the Bracket and alternator is power white remove them both and their hardware, sand or pressure wash them until clean semi shiny metal, dry and reinstall.
You have electrolysis there..and it will also eat a water pump impeller up faster than any acid..The Alternator Bracket and Alternator housing is Aluminum and the block is Steel..(what were they thinking?)
When you go to reinstall the brackets, go to the hardware store and get some aluminum wire compound, and coat everywhere the mount hardware meets steel (bolts, mount surfaces Ect..)
Next get some Wire Braid, (Radio Shack) and install braid from the radiator support to the frame, Fenderwells to frame , hood to firewall, Doors to door posts, gas flap to body, tailgate / Trunk to body.
At each point the wire is grounded, Burnish ALL the paint and grease off to bare metal. Use a proper star-washer and lock. Use sheetmetal or Tech screws where no screws are available.
It sounds like a lot of work, but after you assemble all the parts, it's only a few hours to do..and you'll end up with a system that will work reliably for many years to come..and can eliminate that from your troubleshooting list.
Doc
imp:
"On Eldebrock, On, Isky, On Hemi, On Blitzen.....On Comet, On Cupid, On SBC.."
Slay Bells my ***....NOX2 Powered Reindeer....
Rudolph Had a Lean Cylinder..see the Right Header GLOW?
