Carlos9 said:
What is the safe range for 87 octane. A friend of mine swore I could run 87 with 10.1 compresion. Now I see the importance of piston selection. The piston I was originally going with netted me 9.35:1 with correct pin height 1.56. This place does not have anything in between. Now do we do the same going this route.. meaning using a thicker gasket to lower. Can someone please jot the different gasket sizes (part no's included) so I can tell the amigos what to use either way. I'm a little ticked for straying from the plans.. but I think we can remedy it.
It's funny, the guy told me I'd be at 10:1 with his 1.54 piston.. and I am closer to 10.1 with the correct piston. I think to fix it i just use a thicker gasket.. is this correct. The cam I have calls for a min. of 9.5:1. Will a little more hurt things. This is what you get when you go for good deals. I should have stayed patient and continued building to spec. The good deals turn out to be bot so good in the end.
I don't find the numbers you were given by Silvolite to be that off. So you can take this apart and run your own numbers the formula you need is diameter squared times .7854 for surface area. To get volume, the surface is multiplied by depth. To convert inches to cubic centimeters (which is also milli-liters) multiply English measure by 16.4. To convert linear English measure from inches to milli-meters multiply by 25.4.
If your engine is a 350 at .030 over, I get 727.74 ccs of swept cylinder volume. Swept volume is that of piston displacement. It does not include crown to deck clearance or the gasket.
Your nominal deck is .025 minus .008 or .017, this is 3.55ccs. This of course assumes the engine had the nominal clearance to start with, All we know is it has .008 inch less of what ever that number was. But for argument's sake we'll assume the factory .025 is where it started.
Head gaskets are usually larger than the bore, I took 4.100 X .025 inch thick gives 5.41ccs. There are larger diameter gaskets so this can go to heck easily if you don't watch the part numbers.
The piston you have is .020 further in the cylinder which is another 4.1ccs. There is some benefit to this because the upper .037 inch of the cylinder is going to have a pretty direct path to the cooling system, instead of having to get top end cooling just thru the head gasket as happens with a zero deck block and full dimension (1.56) pistons.
The piston has about 6ccs of valve reliefs
The combustion chamber is 64ccs
This makes a total cylinder volume of: 727.75ccs + 3.55ccs + 5.41ccs + 4.1ccs + 6ccs +64ccs which equals ccs.
The volume above the piston is the total volume of 810.7 minus the swept volume of 727.65 which nets 83.1ccs
810.7 divided by 83.1 gets a static compression of 9.76 to 1. This should be manageable on 91/92 octane with cast iron heads. The squish/quench with a .025 thick gasket and your current pistons is .062 inch. This isn't too bad, it's leaning toward the high side of maximum effectiveness, but is much better than the effective quench you get with a factory circular dished piston.
If you keep your head gasket thin, your compression and squish/quench numbers will be fine with the pistons you have. But the next stop over a .025 gasket will show a marked reduction in compression ratio and detonation resistance; which isn't a direction to move in. I think you're Ok with the basic configuration. Thankfully you didn't use a 76cc head as this would have killed getting any power or efficiency from this engine.
Lots of factors go into the octane an engine will tolerate against compression ratio, so it's hard to tell how your friend gets away with high compression on 87 octane. Lower operating temps, cold air intake, rich mixtures, aluminum heads, heads with fastburn chambers, reduced ignition timing, long duration cams, manual transmission instead of automatic, automatic with a high stall converter, stiffer rear gearing, lighter vehicle weight are examples of things that will let an engine operate with higher compression without detonation. Of course modern fuel injected engines adjust to the detonation limit automatically, the computer just takes out timing lead till the detonation stops and the driver remains clueless. I have a pretty high strung 350 Franken-mouse which is an LT1 top end with the LT4 HOT cam pushing Miller 1.6 roller rockers. Intake is OBD1 continuous flow MAP managed port injection getting air thru a four barrel throttle body built on a Holley 4150 throttle plate. All modified to work on a 880 Vortec short block and stuffed into a 89 S-15. Anybody could do the same thing with Fast Burn aluminum heads and save a pile of effort welding, drilling and milling to get them to flow water in the conventional way. This is my daily driver and parts truck. It'll run on 87 but it ain't as much fun as with 92. On 87 you can hear the headers ring and power is definitely down from 92 octane. That's the effect of the computer pulling the timing back when it gets a detonation signal. Oh yeah, it smogs; but what doesn't come out the exhaust, you can burn off the tires.
