Is there such thing as single stage metallic? How do you protect metallic if it's not cleared?
st3gamefarm said:Yep, there is such a thing. and it's a PITA to spray without streaks and or bloches, and get it wet enough for a good shine all at the same time.
There is really no need for "protection" for the metalics as "it's in there".
The main reason for BC/CC on metalic colors is you can get a nice even coat and not worry about shine, then you clear it, to achieve the shine.
so what are you saying? bigger or smaller tip?cjperotti said:If you were spraying a 2.0 fluid tip, yeah I would say tiger stripping would be expected.
Then how do you explain how you get a lighter color when you spray with more air pressure? I can spray too panels with the same gun but simply change the air pressure on one and you would think I dumped the paint out and poured in another color!cjperotti said:Yes, all the single stages include metallic colors in them and have since the fifties that I’m aware of.
There’s a big misconception about metallic finishes in which it is believed the metallic particles float on top of the surface when painted. That is wrong. When the technician agitates the paint all pigments and metallics become distributed and suspended evenly throughout the mixture. That distribution remains as the technician mixes his formula and applies it to the surface that’s being painted. Therefore, the same amount of metallics visible on the surface is evenly distributed and suspended beneath the surface also. The same is true with basecoat paints.
65ELCMO, the tip you’re using is too large for the metallic colors. Most will recommend a 1.3, 1.4, or at best 1.5 fluid tip.65ELCMO said:so what are you saying? bigger or smaller tip?
It’s a known phenomenon that when you increase the air pressure when spraying metallic colors it will lighten the color.MARTINSR said:Then how do you explain how you get a lighter color when you spray with more air pressure? I can spray too panels with the same gun but simply change the air pressure on one and you would think I dumped the paint out and poured in another color!
They may not "float" on top, but they are plenty exposed on top and WILL be damaged if buffed.
The biggest reasons the bc/cc and the SS will look different is they are two different colors!! Two completely different formulas, two different colors. It has little to do with being able to "see more metallic".
If your theory were correct simply adding clear on top of the SS would produce the same color, and it won't.
I'll have to agree with what you've said. At least that's the way I was taught by my teacher during college.MARTINSR said:Then how do you explain how you get a lighter color when you spray with more air pressure? I can spray too panels with the same gun but simply change the air pressure on one and you would think I dumped the paint out and poured in another color!
How does this happen?cjperotti said:It’s a known phenomenon that when you increase the air pressure when spraying metallic colors it will lighten the color.
Yes, but it doesn't take "jacking up" the pressure. Simple spray technique can produce the same thing and barely any pressure change can do it as well.cjperotti said:Ok, I’m beginning to see where the confusion is coming from. My apologies for not clarifying.
What I’m referring to is the practice of painters who jack up their air pressure trying to spread their metallics properly during application. When too much air pressure is used, it produces a dry effect to the basecoat and even single coat applications. This dry effect produces a lighter tone in the finish. In addition, the metallics won’t lay down as they should when applied properly.
Doe’s this explain it better?
cjperotti said:When blending a single stage you have to use a high grade thinner. No fast dry or medium dry. It needs to go on wet, even the reduced mixture when blending, so as to reduce the cut when buffing. You only get one shot at it. Down the road if it’s buffed again and whoever does, it isn’t aware of the blend a break in the blend will occur.
Brian, I’ve done plenty of blends and perfected my method. It was my little niche to a lot of dealer work with their high liners. And, you’re correct; many of our readers here would not be able to blend as well as I can with single stage. Back when we only had single stage, many painters couldn’t.
I think we’re going to continue to disagree about buffing metallic single stage. That’s ok I can live with it.
Now you bring up waterborne paints. That’s a whole other thread.
Yes, any deviation, no mater how slight, when spraying waterborne is going to affect the result. It’s a difficult paint to spray to begin with. Even before you start your at a disadvantage because the manufacturer uses an electrostatic charge to polarize the coating and assist with the metallic spread and lay down. Moreover, they employ variable shading in the primer; limit the coating so that some of the primer shows through the topcoat, and clearcoat.
Again, waterborne coating is a whole other thread topic.
Of course, they failed down the road. That's not our problem; you as well as I did the best we could with what we had to work with. We did what the customer wanted and demanded we do. We never had a choice in those days. Today we do and have moved forward.MARTINSR said:There is no argument over whether an open blend IS going to fail, WHEN is the only thing to discuss.
Again, you have 2 coats of protection, a foot away you have zero coats. What happens in between? Well it goes from 2 coats to 1 to 1/2 to 1/4, to 1/8 to 1/10 to 1/12 to 1/20 to 1/50 to 1/90 and so on to nothing. That 1/90th of a coat is going to be rubbed off with a friggin rag while washing the car!
An open blend "works" until the car leaves, that is about it. And yes I have seen them last a long time, but I have seen them fail more. And I did a lot of home work on it too and prided myself in doing the best damn blend I could do. And I still feel guilty for all those cars I did open blends on, they failed and now I know it.
wwilliams181 said:I have sprayed metallic single stages in the truck industry for years also. Anything from Centari, Sunfire, Imron, Imron 5000 and the latest PPG 3.5 voc also. I have never been able to color sand and buff without changing the color somewhat. Also never seen a 3.5 blend that has been buffed that didnt look completely like *****......maybe some of the 4.6 voc stuff but never a 3.5. always irritated the crap out of me every time i thought i could do it.![]()
