Hey guys, I did a search on this and found lots of good info on this board. I want to run my plans by you for feedback and experience with sprayable fillers.
I am getting ready to strip and respray my 911. I am an accomplished body man with the right equipment and skills. I want to try a spray on filler this time to level the body panels as opposed to using all 2k primer.
I plan to use PPG DP epoxy primer over the bare galvanized steel. I'll do any body filler work over the DP. I then plan to shoot 2 or 3 coats of Slick Sand over it. The body is pretty straight to begin with, but I plan to "file" the slick sand with 120 dry first to level it, then move to 320 dry and then 400 dry to reduce the sand scratching. I think the 3 coats will provide enough material to do this.
Once done, do I need to apply a 2k primer like K36 and reblock over the slick sand? Or can I shoot a coat of DP expoxy sealer over it and top coat, or K36 wet on wet sealer coat?
Top coat will be DCC single stage Orange.
Any other tips or info are appreciated.
Thanks in advance,
Ed
Thanks in advance,
Ed
