i have a 81 camaro with a 350 sb i want a 454 big block but they dont seem to go into higher rpms. would destroking it to a 427 give me the higher rpms i want? i need sum help
ummmmmmm.....454?18camaro said:so which do u think would be better?
Ayuh,....18camaro said:i have a 81 camaro with a 350 sb i want a 454 big block but they dont seem to go into higher rpms. would destroking it to a 427 give me the higher rpms i want? i need sum help
Im assuming from your user name you have a Camaro! Build a 454 to 1970's LS6 or LS7 specs, put a 2.73 rear end gear in the car and install a 700r4 tranny with overdrive. Install Z rated tires! Pull out onto I-75 or I-95(whichever coast you live closest too)probably late night would be best. As your entering the on ramp, pull transmission into low gear,check mirror for traffic so you can merge onto interstate and firmly plant right foot to the floor completely. Shift transmission to next gear at 6500 RPM. Sooner if you get scared! If you can make it to the 6500 RPM mark in third gear and haven't lost complete control of your bodily functions or already pulled off at the next exit....keep going, you ain't seen top end yet! Click it into OD and prepare for lift-off. You can do the speed calculator for gear ratio(take into account final drive of tranny) and rpm and tire OD and see that on the serious side, you dont need high rpm to go fast....All engines, Big Block or Small Block, have their own pros and cons over the other. Make your choice based on your "honest" needs and desires,and not from others telling you that RPM is the "thing" or its "cool" to twist a Big Block to the moon. I agree with techinspector, 454 is the way to go!18camaro said:i wanted a little higher rpms for a better top speed. but i guess it wouldnt really get to top speed on a track. and it is my daily driver
On the street, torque is always your friend! Just be honest with yourself as to your true needs. How many opportunities in a "driver" do you actually get to twist it up on an average excursion. Probably as you pull back into your driveway is about it. If you live in the city.....too much traffic to get in the 4 bbl. that good. If you live in the country....roads might not be as good for high speed, plus cows are going to be your only audience and they probably wont be too impressed. If you have a dual purpose car(street/strip),then maybe you should let your needs weigh more toward that purpose than street driving needs. If you are only going for street use, I dont know that I would trust the quality of pump gas to feed a real strong running Big Block or any decent running engine for that matter at high RPM. Plus, with pump gas type compression, you will be somewhat limited as to cam selection anyway that would probably work against you trying to run in high RPM anyway. You might still be able to twist it up, but the gain in HP probably couldn't be measured enough to justify it. As compared to much higher compression and more aggressive camshaft profiles that are usually seen in higher RPM performance engines. Many people have the misconception that RPM= HP, and that just isn't always true.18camaro said:haha that sounds raw but idk if i shud got with overdrive or not. u think its that much better?
