Buy "fair" quality tools.
Hi
In addition to everyone else's comments, my advice is to buy your tools locally, where they offer a lifetime warranty, and have replacement stock on-hand. This should be someplace that you shop frequently and is open "off-core" hours, in order to avoid having to make a special trip to get a replacement ... or worse ... having to buy another brand of the same tool just to get the job done.
I still have most of the Craftsman tools that I bought 25 years ago, and that is the only complaint I have against them is the inconvenience of having to drive 30 miles to the city (we live in a small town of 8,000) to get warranty ... if they're open.
Ask about thier replacement policy.
Most companies DO offer a lifetime warranty on basic HAND tools, with exceptions (i.e. hacksaw blades, punch/chisels, etc) so ask what is covered before making the purchase in order to avoid a confrontation later.
Other questions to ask include:
Is it a "free on-the-spot replacement" or a "repair and return" arrangement? Do you have to keep track of and present invoices? Are they going to "hassle" you and blame the broken / worn tools on abuse? Get a business card from the person selling you the tools, and ask him to note the warranty period on the invoice.
Be honest ... and build a good relationship with the retailer. If the 3/8" ratchet has snipe marks on it or a bent handle, it's going to be obvious that you were abusing it.
Think a bit (use common sense) when selecting a tool for the job at hand ... as a general rule, the size of ratchet being used should not be much smaller than the thread diameter of the fastener that you are removing.
Use heat and/or loosen-all on stubborn fasteners.If you use an adapter to accomodate a larger drive in order to provide more leverage (brute force) ... usually one of two things happens: either the fastener or the adapter will fail!
Most air/power tools have a much shorter warranty period, and are often NOT a "free on-the-spot replacement". Most tools of this type will be a "repair and return" warranty. Do they offer a "loaner" or "exchange" unit? Can you afford to be without this tool for several weeks if it "craters"?
I work at a NAPA store, and all of the advice above is what I give to my customers who are considering an INVESTMENT in hand tools. Being a "DIY kind of guy" also gives me a bit of a viewpoint from the consumer side as well.
HTH,
Don
