Hello Guy's.
I'm new here so bear with me...
I'd like to start by saying, I chose this site for a reason.
There is a wealth of information here that I have been drawing from during my entire build. So my situation is unique and I'm hoping we can get to the bottom of this...
My Truck is a 78 C-10. 4360 pounds with me in it. 700R4 Conversion w/2500 stall converter, Corvette servo, and other goodies. Works flawlessly shifting on it's own @ 5800. Yes, I learned how to dial in the governor and cable here on this site.
3.42 Eaton Locker rear from 91 Suburban. Full length headers and X pipe, 2 chamber flowmasters exiting the rear.
Fresh Motor, 1500 miles not using any oil, runs good, pulls good, sounds good.
AFR @ WOT is 13.5 No bog or misfire or pinging ETC.
99 Vortec from different Suburban, block honed and decked 0.20 new cam bearings and freeze plugs. Pistons, rods, and crank were deemed good from machine shop so I reused them.
Heads were milled enough to make them flat, machine shop told me it's better to deck the block than mill the heads a bunch... Stock motor was rated @ 9.6 compression, I'm not sure what it is now. (first build ever, didn't take time to do the math) Used standard Fel Pro head gasket.
Kept my HEI but got a new one from Summit. 34* all in @ 2800 without vacuum adv. during adjustment.
I went with the Comp 276 HR camshaft. 224 230 .502 .510 110 lobe seperation.
Edelbrock Air Gap and Holley 670 Street Avenger. Remember this is a complete Vortec roller motor with fresh rings and bearings and performance valve job and I forgot Beehive Springs.
I was hoping for close to 400 ponies but... Truck did consistent 14.8's when I took it to the track in San Antonio Texas. Top mph was 85.
No excessive spin, it felt like it was doing good, but I was hoping to get a little closer to 13 than that!
Anyone with more experience at the track???
