I have a 70's era SBC 383 stroker that I am having nightmares with. Even if I use no shims all the way up to 6 shims, I can not get the starter to get even close to a paper clip gap to the flex plate. I tried shimming just the outside bolt which did get the starter in close to the gap I need but it still grinds on start up terrible. I have a 168 tooth flexplate and a chevy taho starter to match that tooth # Any help would be awesome. Its as if the holes on the block are too far away from the flexplate. About to ream out the holes of the starter to push it closer but then Id have to shim the bolts to keep it from moving on start up
