Having a heat soak problem with my stock starter, installed a new Powermaster XS high torque starter had the same problem. Has anyone found a starter that will work when hot? Tried a heat blanket that didn't work either.
Boy, I've chased my tail with your problem for a long time. Rebuilt starter, checked and rechecked grounds, new battery, wiring, starter heat shields, and on and on! Finally wired in a remote solenoid and haven't had a problem since. Try it, it's cheaper than what you've tried so far, and may work for you too. Let us know how it goes, and good luck!weirdbeard said:Remote solenoid works every time! no? Thats what I hear.. :drunk:
Copper has a positive temperature coefficient of .393%/°C, which means that a coil that's 1.5Ω at 25°C will be about 2.1Ω at 125°C. This 0.6Ω makes a huge difference in the current through the solenoid coil and its ability to engage the starter, especially when the rest of the circuit is taken into account, like the ignition switch, neutral safety switch and the associated connections and wiring. Applying full battery voltage directly to the solenoid through a low resistence path will greatly increase the chances of the solenoid pulling in.coupe66 said:Don't think any starter will work when the solenoid goes too hot. A hot solenoid means large resistance, and resistance means voltage drop, so the solenoid won't throw out the drive-gear if it don't get the juice...
I had this problem on my tow vehicle,wired it as Doc shows never had a problem again,Johnnydocvette said:Doc here,imp:
Here ya go:
If you don't have points, disregard the "I" circuit..
Docimp:
One problem with this way of wiring ( hard wiring the solenoid to the starter wire ) is that a modern permanent magnet starter will generate enough voltage to keep the solenoid energized for a short period of time after you release the ignition switch. This could cause some concern when the starter doesn't release.larryblack said:Since I put the headers on my 2.8 I too had problems with hot starts.
I added a FORD solenoid but wired my a bit different. I have a short jumper from the battery cable to the start pin on the solenoid. I then have the normal wire activate the remote solenoid. The remote solenoid then sends power down to the starter and solenoid simultaneously. I used #2 marine grade cable. I also took the time to make sure the starter was alaigned within specs too.
True, but some do it and some don't. I had a Delco mini starter knock off on my 34 that would do just as you described. I replaced it with a high torque Powermaster that does not exhibt that problem.onovakind67 said:One problem with this way of wiring ( hard wiring the solenoid to the starter wire ) is that a modern permanent magnet starter will generate enough voltage to keep the solenoid energized for a short period of time after you release the ignition switch. This could cause some concern when the starter doesn't release.
