Do the GM automatic transmissions need to be assembled differently in the clutch packs or drums or retainers etcetera if they are to be used in a very lightweight car?
The GM transmissions appear to be both the most capable and popular units for any automatic transmission performance vehicle.
Unless I’m mistaken, these transmissions, such as the powerglide, TH350, TH400, 700R4, and 4L60(E)/4L80(E), have almost always been used for very heavy vehicles weighing at least 3200LBS.
If these GM automatic transmissions are utilized in a very lightweight vehicle, such as an 2400LBS car, are any changes necessary? It’s 1000LBS difference at least.
I assume these transmissions are assembled with certain characteristics of “preload” or “tolerances”, but I know only a little of assembling automatic transmissions… I do know the GM automatics always pull heavy loads.
Do the transmissions need to be assembled differently in the clutch packs or drums or retainers etcetera if they are to be used in a very lightweight car?
if you take a TH400 or 4L80 from a 6000LBS truck and use it for a smaller engine in a 2400LBS car, I have to assume there would be something that needs to change, but what? Would it just be easier on the transmission with no changes needed?
