Okay, I have searched the forums and haven't found anyone with a similar problem so here goes. I have a 1973 3/4 ton 4X4, 350/350th Chevrolet fleetside with a wood bed.
My taillights do not turn on.
With my headlights off, my blinkers flash, but when I turn on the headlights, the blinkers flash very slowly and are very dim. The turn signal indicators on the dash stay on.
My hazard lights work, but when I turn my left turn
signal on, both rear signals flash.
My brake lights do work.
Reverse lights do not work.
I have made my own harness using the original connectors from the firewall back to the taillight harness, and also made my own taillight harness. The original wires were cracked and cut up in several areas, I figured that was the problem, but the issues persist.
I thought maybe these were ground issues, so to test this, I removed the ground wires from taillights to bed sheetmetal and nothing changes.
I changed the headlight switch and brake switch, still the same. I have not changed the turn signal switch, and the turn signal lever does feel very sticky. I have not seen a bed to frame ground. I would like to put a 4 gauge ground wire from the bed to the frame and will do that soon. Fuses all "look" okay. All sockets and bulbs are new.
I really have no other ideas on what else to look for. Auto-electric is one of my weaknesses, so I'd appreciate any input from you guys. Thanks.
