Th350 problems
7.4K views 6 replies 3 participants last post by  Tyler007
Hey all! Recently I installed a th350 Tranny that I had rebuilt by (Rogers Automotive) 1st off the shop took 3 month to get it back to me and they also did not put the manual valve body in as i requested. The total cost for stall trans rebuild for N2O was $1600. I took the Tranny to my friends shop installed new lines, cooler and ran the fluid in with the truck off the ground and blah blah. Its not my 1st time installing a th350 in the truck. The tranny worked ok did not feel like it shifted like a race tranny. I check the kick cable it was as tight as it could be at WOT plus it downshifted fine. To make a long story short before I put 60 miles on the Tranny it started to slip. I checked the fluid and was like *** metal!
Called up the shop doped it off and told them to fix it. They said I must of installed it wrong I gave him a stern look and said NO I DID NOT! Well now its there and there going to put the Manual valve body in like I requested in the begging.
My question is how do you check line pressure and what ports do I use on the Tranny so I can make sure this one is working before i drive it to the shop for them to check. I am not maid of money and want to cover all ends before the truck goes on the road.
Thanks =)
#2 ·
there is a port on the driver side of the transmisssion bout midway up usuallly a half inch plug, set your high PSI gauge up in there and glance through a th350 manual or even internet it'll give you a chart of what your pressures should be at idle in P aswell as R,N,D,2,1. if you can't find them let me know i just don't have it right off hand now. good luck,
#3 · (Edited)
Thanks I found the flow chart on TCI's site
(shop update)
I called them the other day it's going to cost me $200 for the manula valve body. I also told them to put it on so there is nobody to blam but them this time and its going to cost me anothe $200 to install it. I feel like this right now :boxing:
TH350 Pressure Test
Forward Pattern - P R N D 2 1
Minimum Maximum psi
Park 55-70 170-200
Reverse 80-150 235-270
Neutral 55-70 170-200
Drive 60-90 120-175
Second 75-110 120-175
Low 75-110 120-175
Full Manual Reverse Pattern - P R N 1 2 3
Full Manual Forward Pattern - P R N 3 2 1
Trans-Brake Reverse Pattern - P R N 1 2 3
Minimum Maximum psi
Park 145-170 145-170
Reverse 145-170 145-170
Neutral 145-170 145-170
Drive 145-170 145-170
Second 145-170 145-170
Low 145-170 145-170
#4 ·
(shop update)
TH350 Pressure Test
Minimum Maximum psi
Park 55-70 170-200
Drive 60-90 120-175
Low 75-110 120-175
Minimum Maximum psi
Low 145-170 145-170
A small amount of small metal filings is normal for wear in but if you have an excess amount I'm not sure how going manual valve body will help?
