I have tried to seal this leak about 5 times now, no luck. Never had this problem before. In the past, the first time was always a charm.
I have tried a gasketed housing 3 times and an o-ring housing twice. I have machined the housings on a true lapping stone to guarentee a true flat surface. I used a straight edge on the manifold (BTW, a new Weiand), no problems there. I am using a Stant t-stat.
The bolts are not bottoming out. I used studs a couple times, definetly not a bottom out situation there.
I am using a short wrench to tighten bolts / nuts, definetly not an overtorque situation. I use a lubricant on the threads.
Any suggestions??
Any suggestions??
