How do I go about setting my timing at 36 degree total? Also Do I set it with the vacuum advance connected or disconnected? I think I have an idea of how I am supposed to do it but I don't want to do it wrong.
Thanks
Thanks
The easiest way is to use an "advance" timing light. These have a dial on the timing light that you turn while "timing" your engine to determine what advance your engine is at. You'll need someone with experience to get you started, but here's what you can do... with the light hooked up and with the vacuum advance plugged on the distributor and with the engine "idling" you can move the dial on the advance timing light until the strobe is centered on the harmonic balancers "main" timing notch and "read the dial" to see how much "initial" timing you have. The trick is to zero the time mark on the "main" timing notch by turning the dial on the advance timing light.Canadian_78Z28 said:How do I go about setting my timing at 36 degree total? Also Do I set it with the vacuum advance connected or disconnected? I think I have an idea of how I am supposed to do it but I don't want to do it wrong.
Thanks
