The only credit I get for this one is passing it on, don't know where I heard or read it but it's a handy trick.
When you have to leave say a windshield installed for a repaint and it's the type with the all around rubber seal, use weedeater string to lift the rubber away from the body. This allows you to tape over the edge of the seal and moves the paint line under the rubber seal. Once the paint is good and dry remove the tape and then carefully remove the weedeater string. When you are done it looks like the windshield was removed for paint and if the seal shrinks over time old color won't be exposed.
I'm using this method right now on my son's truck cap. The front window seal is pretty old and not too plyable, but will lift. Didn't want to take a chance of ruining the seal taking it out as I don't know if I could get a replacement.
Lance
Lance
