I understand that, but if that's the only variable you change is the tire size.. Would it be a good idea?
. Frasier, what Vinnie is saying is that we need to know your main purpose(s) for making the changes before we can comment on if it's correct or a good idea...
. BTW, your math above was correct, if speedo says 50, but big tires give 60, then speedo 150 gives actual 180...
< "I have a 96 mustang gt with 4.6 auto... Besides a cold air intake the motors pretty well stock." >
. Figuring this means about 225netHP, which will push a Mustang about 135-140 MPH max with perfect gearing and tire size... that means top speed likely in 3rd gear and no faster in overdrive 4th, it will prolly eventually slow down after shifting into 4th...
. This handy, slick, speedy calculator will give a nice spreadsheet of speeds in MPH per hundred RPMs in all gears vs RPMS vs tire size vs rear gear ratio vs limiting redline/HP peak RPMs...:
http://www.f-body.org/gears (hit 'clear right' button before doing anything)
. To OP, sexypizzaman, wide 35" tall mudder tires have a lot more high speed wind resistance to moving than little 25" car tires... plus trucks usually push much more wind than cars... Oops, just noticed, he was way back in 2008...
