I'm in the process of "re-habbing" my '34 Ford 4dr and starting with the rear suspension. When I first built the car in 1975, I used semi-elliptic springs on the rear which I had removed from the front of a '50 Chev pickup. The springs are still on there, and work well, except I get a lot of bottoming out on the floor pan from a hard standing start, or when the transmission shifts from 1-2 and sometimes 2-3. In addition the pinion yoke hits the floorboard from rear spring wrap-up. I can fix the bottoming out part with rubber snubbers on top of the axle above each spring and some sheetmetal modifications on the floorboard, but I'd like some suggestions on who makes a reliable and reasonable traction or slapper bar setup to eliminate or minimize the spring wrap-up. I don't want a rougher ride. It is pretty stiff right now even with nylon inserts between each leaf spring.
The rear end is a stock '57 Chev 3:55 open, and the transmission is a 700R4 from Bowtie Overdrives with an 1800 stall converter. It is a street car only.
Thanks for your help.
