Ok, I built a 502 and put on a Barry Grant rebuilt Mighty Demon 850. I had rich carb issues from the beginning and ended up getting gas in the oil which washed out the bearings. I have now pulled the motor, which only had 350 miles on it and after replacing the main bearings, rings and polishing the crank I got it back together. I took the motor to a local dyno shop that ran the motor with my carb and it put out 540 horse but the owner told me that something was way wrong with the carb and after a couple other pulls he pulled off my carb and bolted on a new Mighty Demon 825 that was on another motor he had just built and knew the carb was good. With this carb my motor went from 540 horse to 624 horse power. I went home and ordered a new Mighty Demon 825. The tuner at the dyno shop told me to pull out the power valve and put a block off in it and then go up 10 jet sizes front and back.
With the motor back in the car I bolted on the new carb which was jetted 86/86 which is 10 up from where it is from the factory. The car is running rich (smoke coming out of the pipes at idle and acceleration) so I pulled the carb back off and jetted the front to 84, turned the carb over and set the butterflies so they had about .020 of the transfer slot showing, turned the Idle-Eze screw all the way in then back out 1 1/2 all as the instructions said.
Installed the carb and started the car but it would not idle at all. No matter how much I turn the Idle-Eze screw it does nothing. I had to turn the primary idle screw in about two turns to get the car up to idle at 950 which now opens the butterflies way up the transfer slot. When I attempt to adjust the carb by use of the air fuel screws the car runs best when I bottom out a screw, I know this is not right. What gives, what should I try next???? I only have about 10 miles on this fresh rebuild and I am not about to ruin another motor.
Timing is set at 34 total which is as high as I can run it and still get it to start when hot.
