You can rebuild the trans yourself and save big $$$.
Pick up one of the rebuilding videos (just look on the web) and a TH-400 manual and you can easily do the job. You may need to have a machine shop do some minor work if any press fitting needs to be done but it should be minimal.
Make sure you have a TV with the video on your workbench when disassembling and reassembling the trans - trust me it makes all the difference. Also when you disassemble the trans bag each part and label the bag with what's in it. There are a lot of parts inside that thing and you don't want to mix them up.
I had never been inside an automatic before last winter and I spent about three weekends rebuilding a TH-350 for my truck project using the method stated above. Worked very well and was pretty easy. The video is the real key. Some of the techniques shown there save you hours of trying to figure out how the thing comes apart and goes back together.
My rebuild cost me about $160 including a quality shift kit, rebuild kit, and the purchase of a couple "rebuildable" valve bodies I used for parts. I also replaced a couple internal parts with heavy duty versions.
Good luck
Centerline
http://www.hotrodsandhemis.com
