My brother and I have an idea for a cheap turbocharged 350 that runs on E85 since it's plentiful where we live. Grab a vortec motor out of a 96+ chevy truck, tear it down to make sure it's not already eating itself, hone the cylinders, install new rings and gap them properly for boost, add new bearings and a HV oil pump to supply oil to the turbocharger. Add a cheap eBay turbo or any turbo we find laying around. Max boost will be limited around 6 psi so the effective compression ratio would be around 13.5:1 which should work for E85. We will modify a standard carburetor for E85 and blow through capability and use a boost referenced fuel pressure regulator. Is there anything we should do differently? Keep in mind this is by no means a longevity based engine it's more of a "send it 'till she blows" engine built to have fun on the cheap, but we don't want it to explode the first time we try to drive it.
