I’m posting here but it could very well go somewhere else. Just guessing.
1967 Belvedere with 727 3.55:1 gears
I’m experiencing a harmonic vibration that comes in one second intervals. The vibration is in the seat of the pants (and up the back!), goes through the car for one second, one second rest, then repeats. Does not affect steering—no steering vibration.
Things I have checked:
New tires—spin balanced. Vibration was there with old tires and with new tires—no difference.
Front end alignment on target.
Drive shaft balanced. U-joints good. Drive shaft does not demonstrate out-of-balance rotation when checked.
Motor mounts good.
Front suspension good. Tie rods, ball joints, pitman arm ok, greased, no looseness.
Vibration is SPEED specific, not RPM specific. Above 45, vibration begins and continues through 75-80 or even higher mph. No smoothing out so I don’t believe it is caster shake. Below 45, regardless of RPM’s, no vibration.
Things to check next?
Motor mounts good.
