Smth, I'll say one thing for you, you're hard-headed.
What you may not understand is the fact that the last 400 rolled of the assembly line somewhere around 1980. The first one rolled off in 1970. So, that 400 of yours would be somewhere between 32 and 42 years old. Now, in that length of time, nobody knows how many owners the motor has been through and nobody knows what changes have been made to the motor. I said this in the other thread and I'll say it again here. You must know the piston crown configuration and the piston deck height before you make any decisions to change heads. Further, you must calculate your static compression ratio before you can make an intelligent camshaft choice. You can't just throw this together and that together and expect good results. It's no different than anything else, garbage in, garbage out. Is there any possibility of you taking some pics of the piston crowns and showing us what you're dealing with. If you can do that, I can explain how to find the piston deck height with simple tools. Run one of the pistons up to top dead center and take some pics.
