If you are willing to throw some stall at it, and with the deep gears, I think it will be a lot more fun.
I was thinking a 2500 rpm stall would get you there, but Eric is recommending much more. Obviously I'm not going to argue and will defer to him, but I would like to know why he picked that range.
My experience is with street/strip and dragrace background....the single biggest mistake I see hotrodders make, at least guys who plan some track time or at least want to be the hot guy on their block,... is buying too little stall.
They look at "cam rpm range 2500-5500 rpm" and go right to looking for a 2500 stall converter.....that's not going to work the best if you want the vehicle to really jump off the line, as the cam is just starting to come into its power curve but is still quite weak really....it's better to give the cam a little rpm run at the converter first, so the engine is actually really starting to develop some power so it really "hits" strong.
If it was a pure drag only machine, or he wanted an absolute take no prisoners effort out of his 283 on the street, then a 4500-5000 rpm stall would be the place to start.
If you look at competitive Stock Eliminator class type drag racers, something like the 250HP 283(I think that is the original power rating here) in L/Stock Automatic 1966 Chevelle....notice the dyno chart doesn't even start until 5000RPM!!!:evil: And this is a hydraulic cammed engine, not a solid lifter....
NHRA Legal Stock Eliminator 283 Chevy - Hot Rod Network
So that is why you will usually see my converter recomendations higher than most, especially just street cruiser guys. If it is a well built converter, it won't be all "sloppy" or "slip at cruise speed" like the cheap $300 or less 2200-2500 stall crap is.
Another factor in this case is how converters are rated. Common off the shelf stuff typically is built to need 400 ft.lbs torque input to reach that stated stall rpm....his 283 isn't going to make 400ft.lbs at any rpm, let alone anywhere near 2500 rpm, so if he buys a cheap 2500 stall converter he will be lucky to get 1900-2100 rpm stall out of it.
Hopefully that answers a few questions for you guys.
