Here`s what I did to my 4.3 TBI. The list is long.
Block bored .030 Decked .010
Rotating assembly balanced.
Speed Pro Hyper 4 valve relief flat top pistons 1.560 comp height. .015 down in bore at TDC. Stock Rings. .030 thickness head gaskets, .045 Quench distance.
Stock Swirl port heads, 68cc chambers, clean up ported. Fearra 1.94 necked down valves, 30 degree back cut. Springs, locks, retainers to match cam.
Isky Hydraulic roller cam. Computer compatible. Duration @ .050 .204 In. .209 Ex. Lift: .450 In. .465 Ex. Milodon double roller timing set.
Comp Cams Magnum Push Rods. Crane replacement Roller tappets.
Comp Cams 1.6 ratio roller tip rockers.
Edelbrock performer TBI intake.
Stock throttle body, full ported. Fuel Pressure Bung, Adjustable fuel pressure regulator with vacuum compensator. TBI pod spacer.
Venom Injectors. K&N air filter.
MSD spiral core spark plug wires. MSD Blaster coil.
Stock exhaust manifolds. Dual exhaust into turbo mufflers.
5 speed manual transmission. Ram clutch, pressure plate.
3.42 gears. Positraction.
Stock chip. But I plan to get a better chip for it in the future.
It has explosive torque and tachs very quickly. It pulls hard until about 4300.
A vast improvement would have been Vortec heads, which I also plan to add later. It gets excellant mileage. It pulls my 21 foot Gambler bass boat with ease. Cruise torque is high, and you have to be careful, you`ll look at the speedo and your doing 50, you look again seconds later your doing 65.
I wanted something that had a lot of torque in a small package that got excellant mileage, and that`s what it is. It`s a 92 chevy silverado step side regular cab. It was costly to build, that`s one of the negatives.
