what olds. engine do i have
20K views 36 replies 11 participants last post by  mgriff6702
hi i have a 76 cutlass supreme and im trying to find out if i have the rocket 350 or just a regular 350 olds. the number rite above the water pump is 395558 2
#3 ·
Haha, as much as I love Oldsmobile v8's everytime I hear the term "rocket" all I can think about is what DV always says. As willowbilly said above, all oldsmobile 350's are "rocket" 350's. It's just a name. Chevy used to have a ton too. Thriftmaster, Turbofire, etc. Ford did this recently with Triton and InTech. All just a Ford Modular.
Nope. Up until about 1972 there was a W-31 option on the 350 that got better heads and a hotter cam but it was long gone by 76. I think they dropped the rocket moniker not long after 76. They are still a good engine, heads flow decent but they are not a high revving engine in stock form, keep your redline below 5000, say about 4800. The engine will need some serious valve train mods and oiling mods to twist it up.
350 Oldsmobile engines
The 1968 - 1976 Olds 350 engines are more desirable for high performance modifications. The blocks are heavier castings, the heads are better flowing and the crank is heavy duty cast nodular iron. The "Rocket" moniker was dropped after 1975.
The 1977-1980 Olds 350 engines were lightweight castings and the heads were more prone to cracking. The heads have a "PMD" casting because they were made by the Pontiac Motor Division.
#8 ·
engine mods
so how could i get a little more power outa my 76 model 350 with just a little money. like shaveing the heads, diff intake, diff cam what would be the most effective way if i could only do one or two of those things and what name brand would yall go with and thank you all for the info
#9 ·
Wow, lots of incorrect info in this thread!
First, EVERY Olds V8 since 1949 has been called "rocket". The marketing guy who came up with that should get a big bonus. Second, the W31 was made from 1968-70 only and used exactly the same head castings as any other Olds 350 from the same year. Only the valves were bigger. All 1968-76 350s were solid main web, later ones used lightweight blocks with windowed mains. For a street motor, you'll never see the difference.
#10 ·
engine mods
so what ur saying is that i can but bigger valves in the heads that i have and i wouldnt have to change anything else on my engine to compinsate for the bigger valves except maybe the cam and lifters so what kind of mods can i do to my engine to give it more torque with out spending a ton of money on building the engine.
#11 ·
You'll need to verify your heads by casting number. You'll want 350 heads off a 68-70 350 as Joe said above. You likely have #8 heads which have something like a 80cc open chamber and makes for a low compression ratio. The preferable head castings will be #5, #6, #7 and #7a. These have a 64cc chamber. Adding a mild cam and free-flowing exhaust system with a good set of heads will make for a torquey ride as long as you have a decent rear differential ratio in the vehicle it's going in.
If you're going to do anything other than keep the motor running with preventative maintenance, it will likely seem expensive. Such is our hobby.
#12 ·
Yes. Unfortunately, your #8 heads have large chambers. Your best bet would be to get a set of heads from a 1968-71 350 (casting #5, 6, or 7) with small chambers and install the larger valves. The cam and timing will need to be changed to take advantage of this, and you'll want a freer-flowing exhaust.
Of course, the cheapest way to get more torque is to find a rusted out Olds full size car with a 455 and swap that motor in. This is nearly a bolt-in swap.
#13 ·
Right you are that 70 was the last W31. Maybe my memory is clouded but I thought the W31 head castings had a different number. One thing I am pretty sure of is that Olds discontinued the used of the Rocket moniker long before production ended on the engines.
#20 ·
holder4321 said:
so ur saying get a set of headers and change the rear end gears what would u go with 373 or 410 ect... what gear would u go with for a stock 350 olds.
3.08 or 3.23 would be the max Id go with a stock engine,(you probably have 2.56-2.73 stock) you'll still retain your ability to drive on the highway, but deffinitely gain some acceleration.
If you want to include a set of headers with a full dual exhaust, that will add some power, but make sure you buy a quality set, and you will need to re-tune the engine(timing and carb adjustment) to take full advantage of the headers.
Cheap headers fit and perform just like the price.
#22 ·
455
so a stock 455 olds. would be way better then the 350 stock. and everything should just bolt rite up like motor mounts and bellhouseing ect... will there be anything that i would have to change b/c i know a guy wanting 400bucks for a 455 its bone stock but still runs and what gear would u go with on the 455
