M II fit
Some companies build suspensions for full fendered cars that have the upper arm mounted lower with a different crosmember. The geometry is not right, more decamber on hard turns, they might counteract that with some toe out VS ideal turn akerman, and I don't know about tire wear on those designs . Welder series will sell you individual pieces for a mustang II, YOu could keep the lower half of the stock crossmember, buy new blank pieces and refit the a arm lower and reset the Welder series spring top plate angle. set the lower a arm parallel, set the spindle at camber angle, then see where to mount the upper arm mount to clear your fender,
