what is the best thing to use to wipe a car down with before painting? I've heard of everything from alchohol to specially made stuff
I was under the impression wax and grease remover was just fine for final wipe down prior to tack cloth. Is that incorrect?yragat said:I used a wax & grease remover before I started sanding,but thought maybe for final wipe before tack rag maybe I shouldn't use the wax & grease remover...
Its fine. Waterborne however I've been told the solvents are too strong.cboy said:I was under the impression wax and grease remover was just fine for final wipe down prior to tack cloth. Is that incorrect?
Right you are...that does give a better understanding. Thanks Brian.MARTINSR said:... you will get a better understanding on what exactly you should do regarding "surface cleaners".
I think this will help. This guy has been painting a Long time and did Very High end cars..even has his own show nowyragat said:what is the best thing to use to wipe a car down with before painting? I've heard of everything from alchohol to specially made stuff![]()
