What will the Mr. Gasket phenolic spacer do to this torque curve?
3.1K views 12 replies 6 participants last post by  Arns85GT
This is the intake manifold I am using with the Holley 4160.
I am thinking about adding the Mr. Gasket 4 hole 1" phenolic spacer. I think it will put my torque curve further up the rpm scale, but I am also told the 4 hole spacer can improve low end torque.
Does anybody have any experience with this issue? Thanks for the input.
Arn
lluciano77 said:
There is no way to tell. You have to try it and see how the engine responds.
correct.
The spacers work "primarily" becasue they alter the flow pattern below the carb itself and also into the runners. Often making that turn more gentle changes the flow and fuel suspension so noticeable power increases are seen. Sometimes it's more due to fuel atomization than actual air flow increases.
You never can tell what will make more power. Remember, adding a spacer might require rejetting for a true apples to apples comparison.
Remember those "turtles" that used to placed inside the plenums? They did a similar thing by changing the flow patterns.
Spacers & Power
A spacer is going to be used to either fix a problem in the intake tract (plenum length, size, etc) or to help with a heating situation. If the engine was designed and built properly the use of a spacer should actually hurt power and performance. That being said most people cannot afford to have a custom manufactured induction, or valve train systems made. So a spacer will allow you to taylor off the shelf intakes to meet your demands.
Spacers as a rule of thumb.
As a rule of thumb an open plenum spacer will decrease your torque, and throttle response while increasing the engines power band. A 4-hole spacer will generally increase your torque, and throttle response, but move your power band down. The thicker the spacer the more of an affect it will have. Meaning you should see more change from a 2" spacer vs. a 1/2" spacer. Bottom line it's a matter of trial and error to see specifically what your combination wants. I suggest building a combination without a spacer, driving it, and then use a spacer to move the power band where you want it.
#9 ·
Thanks again
The carb is jetted with #49's on the primaries.
I am told the 3.4 liter v6's work best with either the #49 or #47. My .050 over 2.8 is working pretty good right now, but I am looking for more dig out of the hole.
If I need to re-jet after installing the 4 hole, will it normally be up or down? Logic is telling me probably up.
Arn
#10 ·
Jetting with spacers.
Again as a rule of thumb
Normally a 4-hole spacer will increase the air velocity going through the carburetor, requiring a decrease in jetting size, while using an open spacer will decrease the lower speed air velocity requiring an increase in jetting.
#12 ·
smoother throttle response
Well it is in, and although I haven't run it much today, the throttle response is better and there is a smoother torque application at the low end.
I suspect I have gained but I'll know better tomorrow.
Thanks to tech, dawg and xntrik for the help
Arn
#13 ·
Pretty good response
Well, the 4 hole phenolic did as advertised. It definitely improved low end torque a bunch and moved my usable rpm down a wee bit.
From the look of it without a dyno, the car was pulling hard to 6000 rpm but now appears to be pulling hard only to about 5600 rpm. But, that is ok because the cam is really intended to do up to 5500 rpm, so the match is good.
The idle circuit did need leaning out a bit, and I am still testing my jetting.
I'll have the car out to the track in October so we'll see how it does.
Arn
