Hello guys I have not been driving my truck which is a chevy s10 with a 350 sbc and I just had my carb tuned good but had to put a set of new plugs in cause of being gas and oil fouled from swapping out a couple of different carbs to get a good one running nice. The carb was tuned nice and good and did not have any issues with a constant miss till plugs got bad.
Ok I put a 1 inch 4 hole spacer on to have an extra vacuum hookup source for my pcv and I have noticed that while cruising around at 1900 rpm I seem to have a very slight and very faint miss. I don't have any miss at idle or while driving through town just when I am going at a steady 1900 rpm. Could the carb spacer be causing the carb to be doing this?
I read from somewhere that a carb spacer can affect your A/F mixture ratio but I don't know what affect my spacer would have. Would it actually help with my mixture and make it burn better or not? I have not noticed any difference with it being on there just the miss I was wondering about. Wires and everything else is new and the wires are just 8mm stock replacement type.
Thanks guys
Eric
Thanks guys
Eric
