I found this and if everything is correct, it looks like it will work for him.
"Indestructableforce - 6930 is the last four digits of the cam's casting number, 3896930, which also has a horizontal diamond for the casting symbol. The Chevy part number for that cam is 3896929.
In 1967, it was the cam for the 283/195hp; 327/210hp, 275hp, 300hp; and 350/295hp.
The specs on that cam are: (read int lift, ehx lift, int duration, exh duration, rocker ratio) .390 .410 310 320 1.50
In 1968, it was the cam for the 307/200hp; 327/210hp, 250hp, 275hp, 300hp; and 350/295hp.
In 1969, it was the cam for the 307/200hp; 327/210hp, 235hp; and 350/250hp, 255hp, 300hp.
In 1970, it was the cam for the 307/200hp; 350/250hp, 300hp; and 400/265hp.
In 1971, it was the cam for the 307/200hp; 350/245hp, 270hp; and 400/255hp.
In 1972, it was the cam for the 307/130hp; and an optional cam for the 350/165hp, 175hp, 200hp; and 400/170hp.
In 1973, it was the cam for the 307/115hp; 350/145hp, 175hp, 190hp; and 400/150hp.
In 1974, it was the cam for the 350/145hp, 185hp, 195hp; and 400/150hp, 180hp.
In 1975, it was the cam for the 350/145hp, 155hp, 165hp; and 400/175hp. All of these applications had the same specs as the initial 1967 application."
