Steve dellinger said:
Must use e brake every time with Seville brakes to keep adjusted properly. Interesting on having to pump twice because pads retract too far. Could be don't have e brake adjusted properly
Yes, I am aware of this condition. According to one brake source (MP BRAKES) the emergency brake lever must be ratcheted to pre-set the pad position when setting up the brakes initially. Also stated that the emergency brake must be used to keep the rear pads adjusted (as you also stated). I ratcheted the lever but the pads always backed off too far. Bad ratcheting mechanism???
I also found the following explanation on this site. I tried it (changed the 2 psi residual to a 10 psi) and it seems to have worked.
Begin quote:
Now the questions about residual pressure valves--
Many of you will already know that the traditional drum brake systems use a valve inside the master cyl that
traps about 10 or 12 lbs pressure in the system when the brakes are not being activated, to prevent fluid drainback
and keep the brakes ready to act. That has worked great for many decades.
Disc brakes do not like that much Residual Pressure in the system because they don't have return springs or an
internal mechanism to retract the piston.
It is widely accepted that 2-4 lbs residual pressure is ideal for conventional disc brake calipers.
It is enough to prevent fluid drainback, and in most cases keep the brake pads in contact with
the rotor, partly to keep the rotor clean, and partly for instant response. For disc brakes it is desirable to
keep the brake pads in contact with the rotors.
Using 10-12 lbs residual pressure will, in most cases, cause the disc brake pads to rub the rotors a bit more
than is wanted.
Conventional wisdom says that for a front-disc/rear-drum car you should use 10-12 lbs residual pressure for
the drums in the rear, and 2-4 lbs for the discs in the front.
OK so far.
Now when you want to add rear disc brakes, which would give you 4 wheel disc brakes, it would seem to
follow that you would want 2-4 lbs residual pressure for both the front brakes and the rear brakes.. right?
NOT SO FAST! Hold your horses!
The "conventional wisdom" that tells you to use a 2-4 lb residual valve for disc brakes doesn't
take into consideration the fact that not all calipers are the same.
The usual front calipers do not have any return springs or other provision to retract the caliper piston
the brake pedal is released. The usual 10-12 lbs residual pressure in a drum brake system is easily overcome
by the drum brake return springs.
Since the usual disc brake caliper does not have the springs, the 10-12 lb residual pressure will keep the
disc brake pads dragging when the brake pedal is released. That is why you need to change to 2-4 lbs
when changing to discs.
SOUNDS GOOD. When using FRONT calipers on the rear without e-brakes, that is OK.
BUT--- What about the Cadillac REAR calipers with the built in e-brakes and internal self-adjusters?
Don't they have return springs, and a retracting mechanism that retracts the piston?
YES.
And that can save you a bit of work.
When you use the Cadillac rear calipers, you will need the 10-12 lbs residual pressure that is
found in the usual drum brake system.
If you follow the conventional wisdom of taking out the 10-12 lb valve and installing a 2-4 lb valve,
you WILL end up with a low brake pedal that will require one or two pumps on the pedal in order to
bring the pedal up to a normal height.
When using the Cadillac rear calipers, you should leave the stock front-disc/rear-drum master cyl alone. I like that situation. It saves a lot of work changing the pressures in the system.
Just use the Cad rear calipers and don't bother changing the stock master cyl and valves.
They are already just right the way they are.
It's when you try to use non-e-brake calipers (front) on the rear that you complicate things.
For a street car- save the extra work, and be legal-- use the recommended Cadillac calipers.
End quote
