Window cranks for a 72' Chevelle?
3.8K views 9 replies 7 participants last post by  DanTwoLakes
old hacksaw blade
dinger said:
You can make your own with an old choke or throttle cable, the stiff wire type, bend a small hook on the end, hook the loop on the clip and pull straight up. Dan
I made one out of an old hacksaw blade.
Grind all the teeth off, so you don't damage the trim panel.
Grind one end of the blade, making a fairly large notch until you reach the outer edge of the hole.
Bend the remaining material slightly, so that it will sprung out just a little.
Insert the blade between the washer and the handle, and "hook" the closed end of the clip. Pull on the blade, and voila!
