1981 Z28 transmission issues
1 reading
7.6K views 46 replies 17 participants last post by  BogiesAnnex1
1981 Camaro Z 28 350, 399 horse W/ 350 turbo transmission three speed automatic
Hello. I’m working on my 6th transmission on a car I’ve had for ten years. This one was “built “ at a professional transmission shop. Transmission went out just months after warranty expired. Going up a hill and it’s like the car went into neutral. I was able to coast it home. I have park and 4 neutrals now. I put it in drive and I can see the tourqe converter is moving but it’s not translating to my transmission. What could be possible issues?
#2 ·
It is a gen 2
Have you checked the fluid level, engine running and trans in park, at operating temperature?
Torque converter is a fluid coupling, just because the external case is spinning doesn't mean the internal turbine is transferring power to the input shaft.
Low fluid level, clogged filter, broken stator in converter, broken front pump gears, burnt clutches are all possibilities when it won't function.
As a test, start the car and then crack a trans cooler line fitting loose to see if the front transmission pump is actually pumping fluid....if no pumping, you'll have no gear activation in the trans.
#8 ·
Thank you, I will try that first thing in the morning.
Fluid levels appear to be fine. I checked that first thing. I was driving uphill, had it screaming, halfway up the hill it was like it went into neutral. It didn’t make any pops or bangs.
I will drop the transmission tomorrow as well. I will pull a cooler line first, with the car running.
#10 ·
Sounds like pump is fine then, so you can eliminate broken pump gear from the list.
To check further you'll need a trans pressure gauge, to see what pressure is when in each gear position, this would be to diagnose if the manual valve came unhooked inside the pan without having to remove the pan first.
From this point it could be manual valve unlinked, or it broke or stripped splines off a shaft or sun shell or other geartrain failure. Maybe input shaft stripped out of the forward clutch drum. Could also be input shaft spline twisted out of torque converter turbine.
#11 ·
I was going with a pump issue until you mentioned checking the cooler line. Now I am leaning towards the rooster comb coming loose allowing the manual valve to slip out of place. Without a trans pressure gauge available, you would need to drop the fluid and pan to take a look.
And while I don't want to beat on a trans shop - that's never a guarantee that the trans is right. A lot of places pull a unit apart, slap a rebuild kit in it and out the door it goes. Unless broken parts fall out of it, the same hard parts goes right back in it.
#12 ·
Since this car is a 1981.... Does it still have the Thm-350C transmission? Or is there a THM-350 non lockup transmission installed? The lockup converter on the Thm-350C had internal durability problems. A turbine hub broke off would stop all power transfer as you describe. A Thm-350 non lockup converter can have the same turbine hub problem inside , but is far less common of a failure.
#23 ·
What kind of torque you got? Is the same 350 core being rebuilt over and over? Are you sure that the dipstick and tube match? If they don't you could be running a few quarts low of fluid. Also, the cooler could be restricted although not stopped completely.
#24 ·
Sounds like you blew the forward clutch pack Or stripped the spline off the input shaft. With close to 400 HP I would dump the 350 and go find yourself a turbo 400 to bolt in there. Used to rebuild these things back in the late 70s and found many broken 350s. Never saw a broken 400. Burned up clutches and bad seals but never a broken gear set os twisted off shaft.
#30 · (Edited)
Might want to check out 350 and 400 length differences below. Not shown is output shaft spline count which is 32 compared to 27 on the TH350.
Also, the TH400 has electric kickdown. Instead of a cable the TH400 uses an electrical switch that is usually mounted on the carburetor linkage.
Finally, I'd talk to Phoenix Transmissions about your problems before giving up on a TH350. Sounds like your engine's torque (around 400 lb/ft?) can be easily handled by a properly built TH350.
617970
#32 ·
When the other trans have failed, were they taken apart to find the reason they are failing and have they all failed the same way?
Sounds like you need to determine the reason it failed, then you can figure out the cause, and then you can address how to fix it and what trans car needs.
Also is this a simple street cruiser or do you drive this like you stole it, which means your 2 years of fun could be equal to a 100k of easy street driving.
#34 ·
I drive it like I was 16. In town, I drive easy but seldom do I drive under 100 on the interstate. I don’t lite the tires often but I get to the speed limit ASAP. When I drive through Chicago, I race every BMW, Merc, Audi, Mustang etc that pulls next to me. It’s not uncommon to drive 125+ on the 55 or 94.
