32 ford highboy with 383 stroker
899 views 3 replies 4 participants last post by  AutoGear
Okay guys I need help with 32 ford highboy with 383 stroker and weiand 871 blower from Summit Racing. Car has a hard time starting and I feel like it's running rich, What should the psi on fuel be set at (Mine 6 psi). Also what should the timing be set at, as I feel like it down on power. Thank you
#4 · (Edited)
When you say trouble starting; can you please describe the symptoms?
It could be kicking back against the starter
Fuel delivery
lack of enough Spark
Timing
Faulty switch
Give us some more specific symptoms and a basic rundown of the components involved
Fuel Pump, Fuel line size, Holley carbs or Edelbrock? 1:1 throttle linkage or progressive?
What distributor and any CDI box being used? Locked out timing or is it using mechanical advance?
What Heads (or at least iron vs aluminum), Forged or Hypereutectic pistons? Any idea on camshaft? Compression ratio if known?
Is this a gear reduction starter, and are you running this like a typical car with the ignition switch triggering everything? Or do you have a divorced starter, where you spin the engine up and then separately fire the mixture?
What grade of pump gas, or something else?
If you made it this far??? PICTURES!!! :)
