as Tech 1 said, the CR with -5cc pistons and a 64cc head will be 11.0-11.2:1, I have used Eagle cast cranks and their 5140 rods before with no problems turing around 6000rpm (2 different motors, nevery any rot assy issues). I have also used Scat 9000 steel cranks and their 4340 rods and had no issues. I still have a Scat 9000 3.75 crank, 4340 5.7 rods, and KB 18cc dished pistons sitting in my garage from a previous build that once I cleaned them up a bit they still look brand new, and that is with 6-8K miles on them and around 100 passes on them. For the typical hot rod street use either one will do just fine. I
As for "hyper" pistons, I have used mulitple Keith Black hyper pistons, and again I have never had any issues with them. If you are looking for easy streetability, low maintenance. I would suggest getting a either brand kit with the Keith Black hyper 18cc D dished pistons. With the proper .038-.046" quench, 18cc dish, and 64cc heads you will be right around 9.5-9.6:1 compression.
Now as for the cylinder heads, if all you are looking for is a nice street engine (est 425-500hp) then I would not recomend the pro-1 215's, especially not with 3.55 gears, since you will need to pick a cam to match your gears (along with other things). I would recomend either Dart iron eagle platinum 200cc heads if you want to stick with iron heads (cost could be a factor) or with a set of 190-200cc alm heads from one of the major head manufactures. My personal favorite is Dart, but AFR and Brodix are very good as well. Brodix even makes an alm head ment for lower budget builds, these are their IK series. As Tech 1 said, you can get away with more compression on an alm head so if that is the route you plan to take then you could take advantage of this and gain a bit more power buy going with Keith Blacks 12cc dished pistons. Wtih proper quench, 12cc dish and 64cc heads then your will be around 10.2-10.3:1 compression (of the top of my head).
Going strictly on the idea that you are using a 3spd automatic transmission and that you dont plan on changing out those gears for something a bit shorter, as well as the fact that you mentioned that you want a street vehicle (I'm making assumtions here), I would recomend a hyd roller cam with around 225-235° @ .050 which should have around .500-.550". With this cam you will need to get around a 2500-3000 stall (i would go with that later). Also a dual plane intake (ie performer rpm...) and I would suggest using a 750cfm vac secondary carb since it will be a little more user friendly and in my opinion would be the best choice for a street engine.
