Hi
Im building a little ride to cruise around the block
What I know about the engine are
383 chevy with a holley 4160
MSD 8360 blaster 2. Cam comp cam xe268h-10
, Intake Weiland Action Plus 8120,
Edelbrock E-Street Heads, rollers rockers
In the papers there are some reciptes for eagle 5140 i-beam rods, Eagle pistons etc Got a dual AFR guage.
I done the ignition with vacuum gauge and set it to idle 14° with out v.advance and 34 total that seems like a good starting point.
Im will only do a rough tune now as I got alot of other stuff to do.
Only annoying thing I cant leave are that I got a hesitate when throttle from idle.
I idle at AFR 13 but when blipping the throttle the AFR go to 16-17.
How trusty are a fluxulating reading on a AFR meter?
If it is should I look into the acc. Pump circut?
I have rebuilt the holley but dit not put a lot of time checking the clearence for the throttle/acc pump.
