I'm looking for some help. I had a 383 built by a local engine shop and have had very bad luck. The engine shop is very well recognized for the work that they do, that's why I used them. Anyway, I got the motor the first time put it in everything went great break-in etc. Went and had 3" exhaust put on and you could here a knock. Took the truck back to them and they said pull it and bring it back.
So I did and when they took it apart the crank had hit the rear thrust. Ok this is where it gets crazy the guy knows I don't know that much about engines and all that, but even to me this sounds crazy. He said the tranny was pushing to hard on the crank and that's what caused the crank to hit the rear thrust. I told him the tranny and stall converter was rebuilt as well. He seemed to be dead set that the converter bloomed. I call the transmission guy and told him what he said. I think he thought it was a little crazy, but he didn’t seem to have a problem giving me another converter. He said he would put mine on his sons car
Get the motor back put it all back in.
Same thing, that same noise
. So then I called him and he came over to listen to it. Told me that he thought it was the tranny putting a strain on the motor. So I called the transmission guy and told him what was going on and said just so it would clear him of being his fault to put the tranny and bring it to him and he would go back threw it. I get the tranny back in. Went ahead and put a thicker flywheel on. Same thing knock knock and this is no joke
. So I pulled the engine back out and Monday he told me that they found nothing wrong. He said they set-up .006 of play on the crank and it was now .010. He still is hinting that it's the tranny. He said that he was going to go ahead and find a new block and rebuild the motor.
Why would do that if you can't find anything wrong? I hope someone can shine some light on what’s going on with my motor.
Thanks
Thanks
