400"SBC stroked to a 420"?
1 reading
20K views 24 replies 6 participants last post by  redsdad
I'm sure some readers are about ready to hurl at my questions. I notice PAW
offers a SCAT ROTATING ASSEMBLY TO MAKE A 420" OUT OF A 400"
.030 OVER BORE AND 3.875 STROKE USING 6.0 RODS. I CALLED THEIR CUSTOMER SERVICE, and inquired why their 426" rotating assembly was no longer offered. Too many problems. Here is the question, is the extra 14" worth the risk of a shortened life or should I stick with plan A .030 over bore and 6" long rods with SCAT 3.750 stroke? that's it Help please.
4BNBAD said:
The 400 block is bored .030 and crank stroked to 3.875 from 3.750= 420"
I've never heard of anyone running this combination which makes a man wonder why not?
It is more commonly referred to as a 421(420.33 rounded up), common for a lot of Open Modified circle track racers. The reason you may not have heard much about them is that in the past it cost more to build than the horsepower it returned for that added cost, compared to a 406. It only really made a difference to mid range torque, needed off the corner in circle track. Didn't make much sense for a street or strip engine, cost didn't equal output.
It also requires more clearancing of the block, a small base circle cam for clearance and clearance grinding on most of the common performance rods, and a stroker clearance oil pan.
Stroker cranks and pistons are now much more affordable, so more of these are coming out to play. 23° Heads big enough to feed these big SBC's are also more affordable and available today, didn't used to be that way, you needed 18° heads ($$$) to make these big engines shine in the past.
For a street, or street/strip engine, I still don't beleive it returns additional power proportional to the cost of all the stroker specific parts and clearncing needed when compared to a 406, IMO.
I've tried every which way with Dyno programs and can't make the small amount of power gained(25-ish on a 600 hp engine) to equal the added cost of the parts. The added cubes seems to only be good for bragging rights on the street.
Makes more sense to use the 3.875" crank in a 350 block, especially a later roller cam block which has more clearance already, to make a 396 SBC.
#10 ·
4BNBAD said:
Has anyone on this board heard of this combination being used for a street strip truck? and if yes how was the survivability? I'd like my efforts and money to last more than a few drag races.
Nothing basic wrong with it, built with good decent parts it is no more likely to have problems than any other stroker, just costs more for the maybe 20-ish HP more you will get from it. It is a much bigger headache to clearance everything however, takes more time.
Will likely need small journal rods and the rod pins on the crank sized to match, to help with cam to rod and rod to block clearance, and a more expensive oil pan. All that i have been around are this way. You will have to take into account if the pan will fit the chassis you are using, if this is for an S-10 clearance WILL be a problem with the pan.
#13 ·
4BNBAD said:
I see your point and I'm in complete agreement 14" not worth the $3K right on
tell me about this sbc 396" I've never heard about such a thing. What's the point if you already have a good 400" block?
No point if you have a good 400 block, but not alot of those around anymore. Roller 350 block is still an easy find. I was just pointing out a more likely place for the use of a 3.875" stroke crank.
Myself, the only place I would try the 3.875" with a factory block is a roller 350 block. I'd only do it in the bigger bore 400 block if it was a Dart or similar aftermarket block. Wouldn't want to do all that work and have the stock 400 block go "poof!"
#21 ·
ericnova72 said:
Call what you have a 409 around any oldtimers and you will get a bunch of peeved looks and an earful of static when you pop the hood, the Chevy BigBlock 409 W engine was an iconic performance legend in the early 60's ;)
Thats the first thing that entered my mind when he said 409. the BigBlock 409 W with those funkyfide valve covers i love the looks of that old engine.
Now go and get yourself some cheap sunglasses. Quoated from the great sounds of ZZTOP :D
Cole
#24 ·
4BNBAD said:
Stop excoriating such a petty thing I was never too impressed with those strange valve covered motors, evidently chevy wasn't either as the Rat soon followed
If you've seen any of the modern renditions of the 409 W head now that there are a couple of different aftermarket aluminum heads available for them it might change your tune. very powerful and high revving stuff due to the big bore(bigger than 454 BBC) and short stroke. Some of these running in Nostalgia classes are pretty wicked, make a BBC think twice :cool:
#25 ·
4BNBAD said:
The link to 650 HP LS/1 427" I know it is dumb to ask what that brute costs because I know it's out of my price range. Pretty amazing however.
Couldn't find a price. You can call for one. Based on other prices I am guessing $12K.
You can pick up an aluminum 409 block for just a bit over $5.5K.
http://www.worldcastings.com/products/big-block-merlin-409-inchwinch-block.html
Add the aluminum heads on the market and you have a lightweight piece of nostalgia. Up to 540 cubes IIRC.
