Hello. I am new here and i have some questions about putting a blower on my big block 454. it has forged pistons now nice rods and crank. Stock bore with 0.240 thousands dome pistons. Edelbrock performer rpm 6055 heads 2.190 intake 1.880 exhaust. rectangular port. cam is rated for 2,200-6,500 rpm range. 1.7 roller rockers, it is a 4 bolt block. currently running at 10.5-1 compression ratio. I know that is high for street use, pushing around 600hp rite now. Big question is can i put a blower on it and what type should i use, and what other accesseries will i need to make this happen. First timer on the whole blower thing. I've built many big blocks and small blocks but not fresh on the blower bit. any help will be huge thank you. Even part numbers. Thanks.
My profile pic is the engine in question here.
