I have built a 34 ford with a 454 bbc and 700r4 tranny. I have dual Eldebrock 500 CFM carbs (1406) on an aluminum intake. The cam is a thumpr and exhibits a very radical idle. Everything has been tuned and re-tuned but I have one issue that I need some help on. When I crank the engine in the morning and let it heat up to operating temp everything works perfect with the idle circuit and on the acceleration side. I can barely idle at 900 rpms in gear, but it still idles and does not stall. I have a 2500 stall converter in the car. During this particular time I am satisfied with everything from idle to wot. After I drive it for 10 minutes or so and push it a bit the car will not idle period; in gear or out. I hooked up the vacuum advance on the hei dizzy and it made no difference on or off. There is nothing connected to the vacuum ports on either carbs. The engine will run fine when this happens as long as I keep it at 2000 rpms, but nothing below that. I will check the vacuum in the morning to see what I have but it won't run long enough after the test drive for me to check virtually anything. What gives????
