My AC compressor makes a fairly loud rumble noise at idle speed in gear. I checked the pressures and it had 25PSI low, 250 high side. Cools very well and is smooth as silk above idle 1200+RPM. Idle speed is about 1100. With AC on and in gear, it's about 950-1000RPM. The whole front of the engine makes this grinding noise like it's got a bad bearing somewhere.
It has a serpentine belt.
I added 12oz. of 134A and brought the pressures to 35 low and 300 high. The noise is better (different), not as loud and seems more of a fast vibration.
Still cools well. Does anyone think I'm still a little low on gas? The system was completely rebuilt in the early summer of 2007. Everything new except the evaporator.
