OK guys, I just picked up another 509 casting SBC!
This one is really nice with a fresh .030 bore, new cam bearings, freeze plugs, and decked .010.
I found it on marketplace and couldnt pass it up. The only thing I can think will be a problem is the guy didnt use a torque plate when he honed it. I didnt even ask what grit he finished it in, but it looks rougher than 320.
He is an older gentleman, who is retiring from the machining business and had a nice little setup in his garage.
I am seriously debating taking the block in to have it checked over. Things like lifter bores, check the deck and crank tunnel alignment, then finish hone with a torque plate.
I have already asked Speier if my Profilers from him will work on it. (not worried about the steam holes on this one)
Waiting on his answer right now, but I dont see why they wouldnt like a bigger bore. They are a 205 runner, and flow about 300 at .550 lift on a 4.030 bore and go up from there.
I also have a Jones solid roller to match the heads.
Cam is 254/258 @.050
.424/.424 lobe lift
110 lsa
So, I already have a pretty stout 383 short block built for this top end. How much better would this package work on a 406 vs. 383?
Or should I stuff a 3.8750 crank in it, and make a 421?
Or should I just save this block for another build? I can sell the 383 for what I have in it, or save
that one for a different day,,,
.424/.424 lobe lift
110 lsa
