As for the pressure in our cooling systems, there is very little resistance in flow through the system, even with a t stat. Systems equipped with a t stat have a bypass to allow water to recirculate to the inlet side of the pump. Without it, the pump will cavitate. Most t stats have a small bypass hole built into them to help with this as well. If the t stat isn't open, the water will simply recirculate until it does....So the restriction to flow in the system is fairly constant with little change. The majority of the pressure buildup in the system is due to heat and expansion of the coolant AND the air in the system. Like it or not, our cooling systems have some air in them. As the coolant heats up, it expands slightly. This works against the physical restraints of the system, and as a result, creates pressure. The small amount of air in the system does the same. It will build until the cap relieves the excess, whatever it's designed for pressure wise. It will open and close to maintain that set pressure. Once the system cools down, the pressure will drop. However, it needs to cool beyond a certain point for the pressure to completely dissipate, and generally unless you live in a very cold environment, you'll always see some static pressure remain in the system.
