I am looking at getting a dropped (4") I-beam front axle for my 32 Ford. I see that axles are offered in 48 - 46 " widths (king pin to king pin). Any advantages in width?
Deuce said:
A 48 inch axle uses a 2 inch longer spring than the 46 inch axle and I believe the longer spring results in a better ride ... So I try to use the 48 when I can ...
Deuce ... Moderator
home brew said:That is the first time I have ever heard anyone say that. It makes sense but I never thought of it before. :thumbup:
Deuce said:![]()
Ride quality ...
I drive my 32's ... and I want the ride to be the best I can make it. The longer spring really helps IMHO. And that's why I run a coil spring rear end setup. NOT coil - overs but coil springs ... like a late 60's Chevelle design. I use Vega coils ... in a fabricated coil can on the top and fabricated spring mounts on the lower.B]
