So I just got my bottom end back from the machine shop. A very busy and supposedly reputable establishment in Nashville TN.
$1200 later I have a balanced rotating assembly. Honed cylinder bores. A decked block and my pistons hung on the rods. They also straightened out my crank which they said was bent .003, resized the rods and line bored the mains.
They also were supposed to mock up everything and verify all bearing clearances and measurements were correct for me. I told them all I wanted to do was final assembly as I dont have the tools or skills to measure anything plastigauge wont tell me.. And its not all that accurate anyway.
I also asked them to gap the piston rings and hang them on the pistons for me. When I picked up the engine I saw that the pistons had no rings on them. I asked about this and he said he would install them while I waited if I liked. I didn't have time for that. I asked him if he had gapped the rings and he replied that the rings were already correct and did not need to be gapped. I was puzzled and asked him again and he repeated himself. These are total seal brand rings but are not gapless, they are conventional. part number TSR-CR9090-40. I was talking to the man who runs the shop. I figured he was the expert and took his word and went on my way.
Now that I am in the process of assembling the engine I have reached the point where it is time to install the rings on the pistons. I pull the rings out of the box and read the paperwork. In the directions it clearly says "caution... these are file to fit rings"
So I'm now a little confused and frustrated. I get the rings and my feeler gauges out and stick all of the top rings in the bores and square them with a piston. They all measure at exactly .018 gap. Perfect according to the directions.
I then start measuring the second rings. They are waaay to tight. My smallest gauge is 0.010 and they are way tighter than that. Probably about .005. The directions call for .018. So I am at less than 1/3 the recommended gap on the secondary rings. WTF?
If I would have blindly taken his advice and just assembled the engine I would have had broken ring lands in no time correct?
What should I do? Go back and demand that he correctly gap the rings for free? I don't really want to hand gap all of these rings myself with a file, but I may be better off.
Not happy :evil:
Not happy :evil:
