Status
Not open for further replies.
burning up ignition modules, how many volts to coil?
15K views 9 replies 5 participants last post by  EOD Guy
Hi,
I think I have just burned up my second ignition module on my Mallory Unilite distributor. I am also using a Mallory promaster coil (model #29440) but not an in line ballast resistor. Should I be?
The car ran, shut it down and 2 hours later no spark to the plugs again. Coil has 11.7 volts going to it wired off of the ignition switch.
Any help would be appreciated.
Runnin'OnEmpty said:
You definitely need the ballast resistor with the Mallory coil.
Is the Unilite module connected to the coil ignition wiring?
Are you running solid core spark plug wires?
I will get a ballast resistor. Unilite is wired to the Mallory promaster coil via the 3 wire pigtail. Not sure on the wires? Will they say on them?
#10 ·
Do'in the alt swap was possibly the best thing I have done for my car. It's super simple....... basicly jumping the existing wires coming off the external regulator and adding a wire from the radiator support splice/stud back across the radiator support to the external reg area.
The best thing is no more dim lights!
Status
You have insufficient privileges to reply here.
