I was checking the camshaft lobe lift in my stock 302 ford, that goes in an f150 truck, tonight and the lobes are worn real bad. I got to the intake valve on the #2 cylinder and the lift only measured .146 inches as opposed to the .2375 inches my book says. I stopped right there because I know it needs replaced. I've never changed a camshaft before and I am wondering if the bearings should be checked after the cam is pulled. Is there a way to do this? Does it need to be done? Can I put a larger cam in it? Not a huge one but mayby a little bigger. I have a new edelbrock performer intake and edelbrock 600 cfm carb to go on top. Don't know if that info helps. I'm just going to change the cam the way my Haynes manual says. Is there anything else I need to know before I start?
