Which headers should i use on a TA 403?
Hello everyone. I'm in the process of rebuilding/modifying a 403 for a 1979 Trans Am. The car has an automatic transmission. The engine matches the VIN, and that is the only reason I am spending time and money on it, so please no engine swap advice!
I have a set of ported Olds 350 heads (from a 1971 engine), the camshaft (Duration @ .050 is 212 Intake and 218 exhaust) and the intake manifold (Edelbrock Performer non-RPM). I will keep the stock rear end (2.41) and the quadrajet. Now the question is: which headers should I use? I've seen Hooker headers, Hedman, Flowtech, etc. and on paper they're basically the same (tube size, collector size, etc), so it's pretty difficult to make a decision based on those numbers alone. And I don't want to spend $800 on a set of headers which will do basically the same as a $250 set.
Based on the information above, which brand and size headers do you recommend? The car will be used about all the time on the street, but I would like it to do mid-13s on the strip (though I don't know if that's posible with the 2.41 rear-end). Any advice will be appreciated!
